VisionTek Introduces Wallet Drive Portable USB 3.0 2.5″ Drive
For less than $20, this bus-powered, wallet-sized enclosure offers convenience and performance with tool-less design for easy install and hot-swapping of HDDs and SSDs
visiontek_walletdrive2
VisionTek Products LLC, http://www.visiontek.com, a leading manufacturer of award-winning, high-performance upgrades and accessories for PCs and Macs, just announced the ultra-portable new VisionTek Wallet Drive leather external drive enclosure.
The Wallet Drive’s leather cover with magnetic flap closure conceals a hot-swappable, screw-less drive tray with an integrated 7″ long USB 3.0/2.0 connecting cable. Any SATA hard drive or solid state drive can simply be slid into the Wallet Drive to deliver data transfer speeds up to 600MB/s with nearly any Windows® or Mac® OS X based computer with a USB 3.0 or USB 2.0 interface.
Remove and Replace Drives Easily – No Tools or Assembly Needed
To start storing, sharing, and/or backing up documents, and other data with the Wallet Drive, just slide any 2.5″ 7mm or 9mm SATA I/II/III hard drive or solid state drive, including VisionTek’s Go Drive and Racer series of SSDs, into the hot-swappable drive tray. The pressure fit tray snaps tight and securely holds the drive.
Plug and Play Bus-Powered Convenience
Wallet Drive eliminates the driver install hassle and having to carry around a bulky AC adapter. After a drive is slid into the Wallet Drive’s drive tray, the 4.0 ounce enclosure can be connected to a PC or Mac and bus-powered via the built-in 7″ long USB 3.0/2.0 cable.
Turn Storage into a Style Statementvisiontek_walletdrive1
With its natural grain leather finish and fan-less ventilation for noise-free cooling, the Wallet Drive transforms ordinary data storage and back-up into a compact yet stylish high-performance accessory for your mobile technology lifestyle.
Pricing & Availability
The $19.99 MSRP Wallet Drive is available immediately directly from VisionTek, select e-tailers such as Newegg, Tiger Direct, and Dell; and national distributors such as Ingram Micro and D&H. For more information on the new Wallet Drive from VisionTek, as well as their existing mobile storage line, visit: https://www.visiontek.com/mobile-lifestyle/mobile-storage.html
About VisionTek Products LLC
VisionTek is headquartered in East Dundee, Illinois, and can be contacted by calling 866-883-5411 or by emailing [email protected].
