Introducing the EVGA NU Audio Card – Lifelike Audio
There is some exciting news for audiophiles and gamers from our friends at EVGA which is timed with CES 2019. Here is their press release.
January 8th, 2019 – For nearly 20 years, EVGA has built the most powerful graphics cards to play your games at the highest settings, powerful motherboards to run your system at optimal settings, and reliably efficient power supplies to power your system. Now, EVGA extends its enthusiast tradition by partnering with Audio Note (UK), Ltd. to provide the most immersive audio and lifelike gaming experienced on a PC with EVGA NU Audio Card.
Engineered by Audio Note
Audio Note (UK), Ltd. has been in the high-end audio business for over 30 years, making a name for itself by producing a wide variety of analog and digital devices. A core component of Audio Note’s philosophy is to research, design, and build its own components – often custom-made for the specific application – without financial limitations to create the finest audio products available. With this in mind, EVGA partnered with Audio Note (UK), Ltd. to select audiophile-grade digital and analog components and carefully craft the NU Audio card.
With the EVGA NU Audio Card you can experience:
- True Audio – Hear audio as it is
- Lifelike Gaming – Improved and precise enemy detection, and increased immersion.
- Studio and Audiophile Grade – Hear all the subtle sounds, emotional dialog, and powerful explosions to keep you on the edge of your seat.
- Ambient RGB Lighting – Set the RGB lighting to match your mood, or use Audio Reactive Lighting options to let your audio control the effect.
A Completely Different Gaming and Multimedia Experience
High-quality audio is built on a simple premise: everything must be solid from start to finish. One weak link in the chain can turn a symphony into a cacophony. The NU Audio Card is designed to maximize the performance in every major component section:
- Analog – Detail. Clarity. Reality.
- The analog section is responsible for returning audio without distortion and fine-tuning the sound to ensure it remains as faithful to the source as possible.
- Digital – From Source to Playback
- The digital side of the EVGA NU Audio Card is responsible for processing your source audio at the preferred format or converting the audio to and from analog, without affecting the internal makeup of the source audio.
- Power – Good Clean Power
- Powered by Specialized Audio Note (UK), Ltd. audio-grade capacitors and audio-grade resistors, your audio remains noise- and distortion-free as it passes through to your choice of speakers or headphones.
NU Audio Software
From simple volume controls with a sliding headphone amplifier, to creating quick custom EQ profiles, the Nu Audio software avoids the clutter of features that you never use. Customizable audio reactive RBG lighting lets your music choose how your card looks from moment-to-moment.
Available January 16, 2019
Learn more about the EVGA NU Audio Card.
