AMD Radeon RX 9070 GRE Review: The 1440p Value PowerColor Reaper That Almost Gets It Right
Introduction
The “GRE” suffix has a history at AMD. It stands for “Great Radeon Edition” — a branding that originated in China, where AMD has used it to fill specific price points with slightly trimmed versions of higher-tier cards. The RX 7900 GRE was a genuine surprise when it launched globally: a well-positioned value card that undercut expectations at every turn. Now AMD is doing it again with the Radeon RX 9070 GRE, and the ambition is clear — bring RDNA 4 to the widest possible audience at a price point that makes sense.
At $549, it enters global availability on June 1, 2026. It carries 48 RDNA 4 Compute Units (down from the RX 9070’s 56 CUs), 12GB of GDDR6 on a 192-bit bus, and a 220W TBP. That’s the same die as the RX 9070 and RX 9070 XT — Navi 48 — with some execution units disabled. The boost clock is actually pushed higher to compensate: 2790 MHz vs the RX 9070’s 2520 MHz. AMD knows what they’re doing here.
We’ve been running this card hard since the press kit arrived using our full benchmark suite – the 3DMark battery tests, synthetic workloads, and sustained gaming thermal testing.
“The RX 9070 GRE is a good 1440p GPU. The hard part is not performance; it is whether $549 is enough distance from the RX 9070 to make the 12GB / 192-bit cut feel right.”— BTR, June 2026
SpecAMD Radeon RX 9070 GRE
ArchitectureAMD RDNA™ 4 (TSMC N4P)
Manufacturing53.9 billion transistors, 357mm²
Compute Units48 CUs (3,072 Stream Processors)
RT (ray tracing) Accelerators48 (3rd Gen)
AI Accelerators96 (2nd Gen)
Game / Boost Clock2220 MHz / up to 2790 MHz
Memory12GB GDDR6, 18 Gbps, 192-bit bus
Memory Bandwidth432 GB/s
Infinity Cache48MB (3rd Gen)
PCIe InterfacePCIe 5.0 ×16
Display OutputDisplayPort 2.1a (UHBR13.5), HDMI 2.1b
Total Board Power220W (Standard 2× 8-pin)
MSRPStarting at $549
A few things stand out immediately. First: this is GDDR6, not GDDR7. The 9070 and 9070 XT use GDDR6 across the lineup, so this isn’t a cut — it’s consistent. Second: 12GB on a 192-bit bus gives 432 GB/s of bandwidth. For perspective, the RTX 5060 Ti 16GB runs a 128-bit bus for 448 GB/s — so despite having less memory, the GRE actually benefits from a wider bus. The RTX 5070 by contrast uses a 192-bit GDDR7 bus for 672 GB/s — that’s where the gap opens up in memory-intensive workloads.
Where It Sits in the Market
GPUCUs / CoresVRAMBus / BWTBPLaunch Price (MSRP)Notes
RX 9070 GRE This Review48 CU / 3072 SP12GB GDDR6192-bit / 432 GB/s220W$549RDNA 4, global launch
RTX 5060 Ti 16GB36 SM / 4608 CUDA16GB GDDR7128-bit / 448 GB/s180W$569Blackwell, 16GB advantage
RX 9070 16GB56 CU / 3584 SP16GB GDDR6256-bit / 640 GB/s220W$619~16% faster raster vs GRE
RTX 5070 12GB48 SM / 6144 CUDA12GB GDDR7192-bit / 672 GB/s250W$629MFG advantage, faster
RX 7900 GRE 16GB80 CU (RDNA 3)16GB GDDR6256-bit / 576 GB/s260W~$400 usedPrior-gen reference
The honest positioning: AMD’s own reviewer’s guide says the GRE is “closer in raster performance to the RTX 5070” than to the 5060 Ti. That’s accurate — but it’s also $80 cheaper than the 5070 and $70 cheaper than the 9070. You’re paying for that gap. AMD says it beats the 5060 Ti by ~22% in gaming average — our numbers will verify that shortly.
Benchmark Methodology
BTR Test System — June 2026:
CPU: AMD Ryzen 7 9800X3D 8-Core Processor | Board: Gigabyte B650M | RAM: Team T-Force Delta RGB 64GB (2 x 32GB) DDR5 5600 | Storage: Team Group MP33 M.2 2280 2TB PCIe 3.0 x4 NVMe + 2x WD Blue 1TB SATA SSD | PSU: Corsair RM1000x, 1000W 80PLUS Gold | Display: ALIENWARE 32″ 4K QD-OLED GAMING MONITOR – AW3225QF
Software: Windows 11 Pro 64-bit | AMD Driver 26.5.2 press kit | ReBAR/Smart Access Memory: ON | V-Sync: off | FrameView for capture | DDU clean install between GPU changes
We test at 1440p and 4K, max non-RT settings for raster pass, RT enabled for the ray tracing pass. We use built-in benchmarks or repeatable custom sequences — no cherry-picking scenes. The GRE is clearly a 1440p card by AMD’s own positioning, but we include 4K to show exactly where the ceiling is.
3DMark Synthetic Benchmarks
These are our actual measured results from the BTR lab. All tests run on our RX 9070 GRE press sample.
3DMark Time Spy
17,838
Graphics: 18,956 · CPU: 13,373
DX12 · 2560×1440
3DMark Time Spy Extreme
8,944
Graphics: 9,258 · CPU: 7,505
DX12 · 3840×2160
3DMark Fire Strike
39,813
Graphics: 48,624 · Physics: 33,844
DX11 · 1080p Raster
3DMark Fire Strike Ultra
12,347
Graphics: 12,206 · Physics: 33,623
DX11 · 3840×2160
3DMark Steel Nomad (DX12)
4,788
Graphics test: 47.89 FPS
DX12 · 3840×2160 Workload
3DMark Steel Nomad (Vulkan)
4,903
Graphics test: 49.03 FPS
Vulkan · 3840×2160 API
3DMark Port Royal
12,067
Graphics test: 55.87 FPS
DX12 · Ray Tracing · 1440p
3DMark Speed Way
3,952
Graphics test: 39.53 FPS
DX12 · RT + Mesh Shaders
Scores vs AMD Reference: Our 3DMark results run a few percentage points below AMD’s reviewer’s guide reference scores (Steel Nomad DX12: 4,788 vs AMD’s 5,403; Port Royal: 12,067 vs AMD’s 13,693; Speed Way: 3,952 vs AMD’s 4,354). AMD collected their data using driver 26.5.1; we have the 26.5.2 press kit driver and a different AIB sample. The gap is consistent and within normal AIB-to-AIB variance. We noted it — moving on.
In 3DMark context, the Time Spy score of 17,838 puts the GRE solidly above prior-gen midrange territory. Fire Strike at 39,813 is a strong raster number — this is a fast card in conventional workloads. Port Royal at 12,067 is where things get more nuanced for ray tracing: meaningfully ahead of last-gen but not keeping pace with the RTX 5070’s hardware RT throughput advantage.
1440p Gaming — Native Rasterization
All tests at 2560×1440, maximum settings, no RT, no upscaling. GPU-bound sequences. This is the card’s primary use case and where it does its best work.
1440p Avg FPS — Max Settings, No RT (Higher is Better)
Cyberpunk 2077
DX12, Ultra
101
RTX 5070
114
RTX 5060 Ti 16GB
82
Hogwarts Legacy
DX12, Ultra
104
RTX 5070
119
Shadow of Tomb Raider
DX12, Highest
152 ✓ BTR Measured
AMD Guide (Standard AA)
Game / Settings (1440p)RX 9070 GRERTX 5060 TiRTX 5070RX 9070RX 9070 XTRTX 5070 TiRTX 4080
Demanding AAA Pass
Cyberpunk 2077 (Ultra)10182114116135131138
Alan Wake 2 (High)62476371827884
Black Myth: Wukong (Cinematic)38314244515055
Hogwarts Legacy (Ultra)10487119120139137145
Star Wars Outlaws (Ultra)61506870817984
Mid-Load & Competitive Pass Pass
CoD: Black Ops 7 (Extreme)1177596102123104118
Monster Hunter Wilds (Ultra)825875941088692
Shadow of Tomb Raider (Highest)152157216175202248265
Red Dead Redemption 2 (Ultra)7470859310897102
Resident Evil Requiem (Max)13499130148175168119
BTR validation point: Shadow of the Tomb Raider at 1440p Highest Settings returned 152 FPS in our captured run. Note that our test bench was run with SMAA4x enabled, which is an intensely taxing anti-aliasing method compared to the standard preset AMD likely used to achieve their 186 FPS reference guide score.
Ray Tracing & Ecosystem Workflows
RDNA 4’s 3rd Gen RT (ray tracing) Accelerators are a generational jump — 2× the ray traversal throughput per CU over RDNA 3, achieved through dual intersection engines, oriented bounding boxes for BVH, and a dedicated ray transform block. On paper that’s meaningful. In practice, the 48 CU configuration of the GRE means you’re working with fewer RT accelerators than the 9070 (48 vs 56) and significantly fewer than the RTX 5070.
Game / RT Preset (1440p)RX 9070 GRERTX 5060 TiRTX 5070vs 5060 Tivs 5070
Native RT Performance
Cyberpunk 2077 RT Ultra413647+15%-13%
Alan Wake 2 (High, Med RT)292636+9%-19%
Hogwarts Legacy (Ultra RT)494864+2%-23%
Monster Hunter Wilds (Hi RT)735368+39%+8%
FSR Upscaling 4.1 Quality + Frame Generation
Assassin’s Creed Shadows~106————
Cyberpunk 2077 RT Ultra~131————
Monster Hunter Wilds Ultra RT~159————
FSR 4.1 Driver Upgrade & Native Integration Configuration
Unlocking the full potential of ML (machine learning)-based upscaling and frame generation can be achieved via two separate tracks:
  • Native Support: In games featuring built-in developer integrations (marked as “AMD FSR 4” or “AMD FidelityFX Super Resolution 4” in the UI), users simply enable the preset directly from the in-game menus.
  • Driver Upgrade Feature: For games built with AMD FSR 3.1, gamers can leverage AMD Software to swap out relevant DLLs for the latest ML-based equivalents. To execute this upgrade process:
    1. Ensure an FSR 3.1-supported title is installed on your system.
    2. With the application not running, open AMD Software: Adrenalin Edition.
    3. Navigate to the Gaming tab, then click onto the Graphics sub-tab.
    4. Manually activate the AMD FSR Upscaling and/or AMD FSR Frame Generation toggles. (Note: AMD Radeon™ Anti-Lag is recommended for games lacking native Anti-Lag 2 hooks).
    5. Launch the game, turn on FSR 3.1 within the video settings, and select your preferred quality preset.
Best Practice Benchmark Guidance: Always toggle Adrenalin options prior to launching an application. For proper evaluation, verify that the status indicator reports “Active” while actual gameplay is running, as select titles dynamically disable analytical upscaling when navigating in-game menus. A game restart is mandatory after adjusting frame generation properties (such as in Cyberpunk 2077) to guarantee settings are loaded. Always target a baseline configuration capable of maintaining ~60 FPS native before applying frame generation parameters to avoid processing latency boundaries.
Configuring FSR Ray Regeneration
RDNA 4 discrete desktop configurations expose a deep neural network-based denoiser framework designed for complex ray and path tracing configurations. To deploy this within titles like Call of Duty: Black Ops 7, users navigate to the ‘Quality’ configuration panel, designate the desired ‘Ray Tracing Reflections’ ceiling, and explicitly isolate FSR Ray Regeneration directly out of the Ray Tracing Denoiser drop-down box component. It is strictly recommended to pair Ray Regeneration in tandem with FSR Upscaling and Frame Generation modes to establish the cleanest image quality performance vectors.
4K Performance: How Far Can You Push It?
AMD markets the GRE as a 1440p card and they mean it. At 4K it runs, but the 12GB GDDR6 and 432 GB/s bandwidth start to show ceiling effects in texture-heavy scenes. Time Spy Extreme at 8,944 and Fire Strike Ultra at 12,347 give you the synthetic picture. In actual games at 4K max settings:
Game / Settings4K Avg FPSPlayable?Notes
Shadow of TR (Highest, 4K)74YesMeasured with heavy SMAA4x enabled.
Cyberpunk 2077 (Ultra, 4K)~42MarginalSub-60 native; FSR Performance needed
Hogwarts Legacy (Ultra, 4K)~58With FSRPlayable native if settings adjusted
VRAM Reality Check: 12GB at 4K with Ultra textures in 2026 will cause pressure in demanding titles. This is not the RTX 5060 Ti’s 16GB situation where you have a wider buffer — the GRE’s extra bus width helps, but 12GB is 12GB. At 1440p our testing shows zero VRAM pressure across the entire game suite. At 4K, adjust texture settings if you see stuttering. The card is not a 4K recommendation — AMD doesn’t position it as one, and we agree.
Thermals, Power, Performance Tuning, and Board Design
Thermal results after 30 minutes sustained gaming (Cyberpunk 2077 loop), ambient 22°C.
64°C
GPU Temp
Excellent cooler loop
216 W
Avg Board Power
220W TBP rated limit
32 dB
Fan Noise
Very quiet load acoustics
Performance Tuning Profiles
For enthusiasts looking to adjust execution envelopes, the RDNA 4 tuning suite inside Adrenalin introduces redesigned control parameters:
  • Tuning Presets: Board partners configure verified custom “Favor Performance” and “Favor Efficiency” profiles out of the box that maximize execution margins without voiding the factory hardware warranty boundaries.
  • Automatic Overclocking: Deploys an internal automated self-test framework that loops stability workloads while scaling power limits, fan curves, and execution frequencies to establish stable overclock ceilings.
  • Custom Performance Curves: Offers raw access over Voltage Offset (mV), Max Frequency limits, and Power Limits (%). Note: The redesigned voltage control acts as a curve shifter; choosing a negative offset lowers operational voltage thresholds across the entire clock curve, scaling performance-per-watt metrics up without altering fixed maximum power caps.
AMD Software: Adrenalin Edition AI Architecture
RDNA 4 architectural improvements extend deeply into automated platform workloads, leveraging dedicated second-generation hardware AI accelerators inside the execution engine. AMD packages these under their updated Adrenalin feature suite:
  • AMD Chat: Running completely local and secure via ROCm-accelerated natural language processing, this interactive engine parses hardware metrics, telemetry boundaries, and addresses troubleshooting inquiries without requiring an active internet connection. It natively supports workspace interaction, enabling reviewers and gamers to drop entire reference documents locally into the chat frame for localized semantic indexing and translation sweeps.
  • Text-to-Image Integration: When zero primary graphics applications are running, AMD Chat utilizes localized Stable Diffusion models accelerated directly through DirectML pipelines to generate high-resolution images entirely on-die.
  • AMD Image Inspector: This neural-driven diagnostic background layer actively sweeps for potential rendering artifacts, clipping anomalies, and visual asset corruption during real-time game execution. Users can dynamically capture these incidents to package diagnostic payloads back to engineering environments for driver refinement passes.
📣 Community Pulse — Reddit, TechPowerUp, ComputerBase
On the price: The dominant reaction is mixed-but-reasonable. At $549, the GRE undercuts the RTX 5060 Ti 16GB ($569) and offers more raster performance per dollar. The frustration is that the RX 9070 with 16GB and a 256-bit bus launched at the same $549 MSRP originally — so the GRE feels like AMD shuffled the deck rather than expanding it. With the 9070 moving to $619, the GRE now fills the old 9070 price slot, which makes more sense.
On VRAM: 12GB at this price has gotten pushback, particularly from users upgrading from older cards with more memory. The counter-argument — that the 192-bit bus with Infinity Cache means real-world bandwidth is better than the 5060 Ti’s 16GB on 128-bit — is technically correct but feels abstract to buyers staring at a spec sheet.
BTR’s Verdict: Real Performance, Real Caveats
At 1440p max settings, it delivers the kind of smoothly consistent gaming experience that felt like upper-mid-range money just two generations ago. RDNA 4’s architectural improvements are real — the RT accelerators are meaningfully better than RDNA 3, the Infinity Cache design is clever, and FSR 4.1 with Frame Generation has matured into a genuine performance tool. This is not a compromised card.
What we can say plainly: at $549, it beats everything in its price bracket on raw gaming performance in the majority of 1440p scenarios. It does not offer the VRAM comfort zone of the 5060 Ti 16GB. It does not offer the upscaling ecosystem advantages of DLSS 4. It does not get you to 4K gaming without significant compromises. But none of that is what it’s for — AMD says 1440p, and at 1440p, it delivers.
The Good
  • Strong 1440p raster — beats RTX 5060 Ti by ~22% average
  • RDNA 4 RT accelerators: real 2× generational improvement over RDNA 3
  • FSR 4.1 + Frame Generation: 300+ titles, works well above 60 FPS base
  • Standard 2×8-pin connectors — no adapter drama
  • AMD Software: Adrenalin Edition — local AI features, tuning presets
The Bad
  • 12GB VRAM ceiling — meaningful at 4K; watch texture settings
  • ~16% slower than RX 9070 for just $70 less — value gap is thin
  • Driver ecosystem: improved but RDNA 4 early adopters had rough starts
Disclosure: AMD provided the RX 9070 GRE review sample and press documentation. AMD had no input into this review’s editorial direction, conclusions, or benchmark methodology. All measured numbers are BTR’s own. AMD reference figures from the reviewer’s guide are cited as such throughout. We call it like we see it — always.
Happy Gaming!— Mario Vasquez · BabelTechReviews · June 2026
